Better Backup/Restore functionality for Multi-Instance installations
Discussion in 'Ideas' started by Anonymous, Dec 23, 2015.
  1. Anonymous
    Anonymous Guest
    After discussing with Support (Ticket ID 1170), the proper procedure to backup/restore/migrate a single instance from one Multi-instance Server to another, I've been told that this is not possible at this time (V14SP2). I'm told that Back/Restore is only available for ALL instances at the Instance-manager level or from within the instance itself, which brings its own headaches with restores back to the same instance on a different server. I'd love to see a good way to do a SINGLE instance backup/restore at the manager level.
