Better Management Of Generated Call Reports
Discussion in 'Ideas' started by Frick, Jul 3, 2017.
Better Management Of Generated Call Reports 5 5 1votes
5/5, 1 vote
  1. Frick
    Jun 2, 2017
    9
    5
    I have found the management of generated call reports is lacking in functionality. Here are some features I would love to see:
    • Ability to lock individual reports to keep them from getting deleted
    • Ability to select multiple reports (check boxes?) at a time for deletion
    • Ability to schedule auto-deletion of generated reports that are older than X days (those reports that are locked will not be deleted).
    Currently having to deleted every report individually is quite cumbersome.
    Thanks!
