Better provisioning of Yealink EXP39 sidecar**AWAITING F/B
Discussion in '3CX Phone System - General' started by igor.snezhko, Mar 22, 2011.
  1. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Let me describe a problem.
    When you set buttons at 3CX interface like this:
    [​IMG]
    You will see this on LCD display of sidecar:
    [​IMG]
    But I want see a real names here, so I go to phone WEB page and fill Labels manually
    [​IMG]
    Now I see real names
    [​IMG]
    So, you need to fill the sidecar Label field with "Last Name First Name" of BLF or Speed Dial user Extension.
    Hope, you understand me :D
  2. paul1
    Jan 14, 2010
    80
    Re: Better provisioning of Yealink EXP39 sidecar
    I agree. That would be very helpful!
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    I understand you - I do this for polycom already. 3CX template parser is capable of doing this.
    Forwarded to Yealink for quick review. WIP
  4. countrycomp
    Dec 2, 2008
    53
    Re: Better provisioning of Yealink EXP39 sidecar**AWAITING F
    And in the three EXP39's that I have deployed so far, the users all wanted the extension numbers to be vertical eg 201,202,203,204 etc on the left side and 220,221,222,223 etc on the righthand side.
  5. gnezdin
    Mar 24, 2011
    I agree, this is strongly needed. If I'd need extension numbers I would buy EXP38 and not the more expensive EXP39 :)
  6. running
    Jun 24, 2011
    37
    Has this been added to template? We are interested in this.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I would expect this to be an easy fix in the template that you can do yourself. I do not have one of these devices to test.
    I see this in the template now: Key1.Label = %%blffirstname11%% %%blflastname11%%
    So a combination of what it was before I can only assume... something like %%blfextension11%% but can't be sure.
    In this case the 11 is the BLF I am taking programming info from for the extension. Key 1 is the first key of the sidecar.
