Better support for Circuit / Internet Failover
Discussion in 'Ideas' started by sean.suntelnetworks, Mar 8, 2017.
Better support for Circuit / Internet Failover 5 5 5votes
5/5, 5 votes
  1. sean.suntelnetworks
    Oct 10, 2014
    34
    Currently, there is a requirement for on the Network> Public IP tab for a singular static IP. However, it looks like 3cx has the ability to use 'stun' but 3cx officially doesn't support it.
    It would be nice if a primary internet circuit dropped (common in Tampa, Florida over the past 12 months), that a 4G or alternative circuit could take its place.
    With Mikrotik, I can script 2ndary wan failover to happen on the fly. However, the external IP will change, and unless the IP changes inside the "Public IP" area, I've had issues with 1 way audio.
    I'd like there to be a '2ndary' Static Public IP field that could be used when either there is an DNS resolution/Network Failure. This way internet failover could happen without any human intervention and keep the client (or enterprise) up.
