Better Transferring Options
Discussion in 'Ideas' started by Brian A, Jan 16, 2018.
  1. Brian A
    Jan 16, 2018
    Thinking through the customer experience, I think something like this would be very helpful:
    Possibility #1: After hitting TRANSFER, there is an option for "Blind, Attended, to VM" -- then they can either enter EXT or directory to find the contact.
    Possibility #2:
    1. Reception does attended transfer, but person doesn't want the call.
    2. Reception can hit a button that auto transfers back to that persons voicemail.
    Thanks,
