In Progress Better UI for BLFs - Queued for Development
Discussion in 'Ideas' started by jbryant84, Jan 31, 2017.
In Progress Better UI for BLFs - Queued for Development 5 5 86votes
5/5, 86 votes
  1. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    Right now the blf ui is very plain, and can be cumbersome. If you miss one or have a duplicate you have to start from the point you screwed up and roll your changes out all the way down. It would be great if there was an option to insert or delete rows, and line numbers would be nice too, even if it was every 10.
  2. nasaw
    Jan 2, 2017
    I agree, BLFs in general need a thorough makeover.
    The Move Up/Move Down buttons already exist in the inbound/outbound rules section. Just need to re-purpose it for the BLFs
  3. eli
    eli
    Feb 25, 2012
    8
  4. two
    two
    Jun 25, 2015
    15
    7
    Great point! Especially when there is over 50+ and your client wants a specific order on ALL 50+ sets. Time consuming and frustrating!
  5. Jazz Oberoi
    Feb 17, 2017
    12
    5
    +1
    Also, have an option to start adding the BLF's on the expansion modules (like EXP40) instead of the integrated phone.
    Brad Cann and Scott Coleman like this.
  6. techclarity
    Nov 14, 2014
    90
    36
    Or better yet, offer a customized page layout for supported phones that matches the BLF layout of the phone. This would make it real easy to configure and view what the phone will look like.
    the60 and Scott Coleman like this.
  7. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    BLF "templates" for different departments would enable fast, easy & accurate BLF key assignments to new endpoints. (accounting gets layout A; shipping gets layout B, etc.)
  8. jbryant84
    Apr 6, 2016
    106
    38
    When setting up a new extension, you have to start from scratch. You can't copy from one extension to another. That would be great as well. However the more simple request is the more likely it is to get implemented
    Scott Coleman, two and parachutech like this.
  9. solutionsit
    Nov 25, 2014
    62
    5
    BLF now in version 15. With sidecars on a yealink you need to add 27 blfs to get the side car. Which is fine. 2 things would help. A number beside the blf spot as well as adding blfs in blocks instead of one by one.
    jbryant84 and Scott Coleman like this.
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,888
    190
    We can add copying BLF from another extension ?
    two, the60, yanceyworks and 1 other person like this.
  11. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    yes- copying BLF's from another - or "Create Extension from Template" - the template would have specific settings and BLF's configured.
    Matthew Domer and Nick Galea like this.
  12. Nick Galea
    Jun 6, 2006
    1,888
    190
    OK, let us research this and see how we can make this happen
    two, craigreilly and jbryant84 like this.
  13. wcoggins
    May 8, 2014
    17
    15
    I agree with everything noted about the BLFs so far. The method of administering the BLF keys has gone BACKWARDS in functionality.
    Having to count spaces on a screen instead of having BLF keys numbered is silly. What happened in the last version?
    Being able to copy a BLF map from one extension to another is very useful. The old 3COM phones showed an actual map of the BLF key positions.
    All these things make it much easier to administer the 3CX system thus allowing customers to get the End User wants. The quicker and easier it is to administer these systems the easier it is to sell. More sales = more Money!
    two likes this.
  14. craigreilly
    Feb 1, 2012
    2,962
    180
    Nick - while you are looking at this - would there be an opportunity to add a BLF for Paging Extensions?
    Parker likes this.
  15. user253831
    Dec 7, 2016
    5
    We´d appreciate research on this, since provisioning BLF of phones is hell (even with 10 or 20).
    Especially when you want to sort the BLF buttons in alphabetical order.
    And when a new employee joins (or leaves) you have to edit ALL extensions and re-provision EVERY telephone to roll out the new blf setting.
    Editing the phone template with fixed BLFs buttons is a workaround, but also painful and can lead to problems. And with every config-update 3cx provides, you always have to customize it again and again (when you don´t want a separate profile).
    #15 user253831, Apr 25, 2017
    yanceyworks and nasaw like this.
  16. Samuel Fishman
    May 4, 2017
    6
  17. two
    two
    Jun 25, 2015
    15
    7
    Nick this is one of the most cumbersome parts of companies with continual change. Its very time consuming without insert, add, move up/down capabilities. Any assistance in speeding this change would be greatly appreciated!
    Neil
    CentrexJ likes this.
  18. Nick Galea
    Jun 6, 2006
    1,888
    190
    This is an area that has our attention and once we have our SP1 out of the way we will be able to focus on a major update in regards to easier, more centralized and more configurable IP Phone configuration
  19. sysadmin_at_lca
    Jul 8, 2014
    6
    Having the ability to move up/down/insert/delete would be great.
    If it went further and we could:
    - build a "template" that said Button1=Line, Button2=SP1, Button3=SP2, Button4=Queue In, Button5=Queue Out - call the template "Site A"
    - be able to apply the BLF template to extensions as you add them.
    So when you commission a phone for Site A I can choose the template "Site A" and know they'll get the standard buttons I want them to have (including the 2 shared parks that relate to their specific site).
    Going a step further if you added to the template:
    - timezone, date and time format
    - outbound caller id
    - voicemail and forwarding defaults
    - options
    And each of these items in the template would be:
    - mandatory - you get this and can't change it
    - default - you get the setting when the extension is setup, but can alter it after
    - not set - use system default/blank
    jbryant84 likes this.
  20. carbm1
    Nov 3, 2017
    Any updates on this?
    Manually programming in 30/40 intercom buttons on an expansion module is getting old. Especially trying to keep it in alphabetical order when some one new comes in. I can't just move the whole list down. I have to copy and paste several dozens times to move things around.
    yanceyworks likes this.
