Big Problem after update from 15.5.1136.6 to 15.5.3849.1
Discussion in '3CX Phone System - General' started by haldop, Aug 29, 2017.
  1. haldop
    Aug 29, 2017
    6
    We have Debian server with 3cx. After update there is no audio in external calls (inbound and outbound). Phones are ringing, we can make calls but we cant hear anything after answer. In Windows clients is the same. Internal calls are ok, no problem.
    Have You any ideas where to look?
  2. smario
    smario Support Team
    Dec 14, 2016
    21
    How did you install Debian? - From our ISO, installed on the cloud?
  3. haldop
    Aug 29, 2017
    6
    Cant remember... But it is Debian you recommend and it is VM on our HyperV server.
  4. haldop
    Aug 29, 2017
    6
    :~$ cat /etc/debian_version
    8.6
    It was installed from ISO but where I get it... I think from Debian site, 3CX was installed later. Debian was clear and it is only for 3CX.
    Have You got ISO with preinstalled 3CX? Or maybe VHD with ready to go PBX?
  5. haldop
    Aug 29, 2017
    6
    It was definetly update problem. Restoring yestardays backup of entire VM resolve problem - it is working now with version 15.5.1136.6.
    No support, thank You. :* Do not want this "final" version.
  6. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @haldop,
    The majority of our customers use the 15.5.3819.1, having no problems when upgrading from an older version. I would reccomend you to use the latest version of PBX for various reasons, so please do upgrade to the latest one, and we will gladly assist you if any problem occurs.
    After you upgrade, if the same problem occurs, do the firewall check and let us know of the result. Also, so far have you been using the reccomended ports for PBX(especially RTP ports)?
