Billing Code "**" and Outbound Rules
Discussion in '3CX Phone System - General' started by Mullenlaw, Dec 6, 2011.
  1. Mullenlaw
    Apr 13, 2011
    53
    Could someone point me in the right direction?
    As I understand, you can have the call log record additional information (aka Billing codes) if you dial
    "targetnumber**myinfo". Is that correct?
    From what I have read, anything after ** is stripped from the dialing.... Correct?
    If that is correct then how do you configure the Outbound Rules? The system log says it can't find a matching outbound rule.
    Also if I try "extension**myinfo" the calls goes though (not outbound) but the "myinfo" is no where to be found.....
    10,586
    252
    But your outbound calls do work, if you leave off the **billingcode ?
  3. Mullenlaw
    Apr 13, 2011
    53
    Yes they do....
  4. leejor
    10,586
    252
    Have a look at this thread, particularly Nicky's post.
    http://www.3cx.com/forums/code-for-outgoing-calls-8230.html#p42133
    It seems you will have to modify your outbound rules to accommodate the length of the numbers including the ** and billing code.
