Billing code reporting feature
Discussion in 'Ideas' started by 3CX inquiry, Apr 11, 2018.
  1. 3CX inquiry
    Apr 9, 2018
    I'm not sure why was the billing code report feature was removed in 3CX v15. This feature was very useful, is there a chance for it to be added back?
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    722
    123
    Is that so? If that is true, then you might want to take a look at our 3CX Enhanced Billing Codes add-on. It does everything the old system did, and more. For example, it will enforce the use of billing codes, and verify the billing code entered is valid, and auto generate reports and send tailored reports to each manager, etc.
