Billing Code
Discussion in 'Ideas' started by compet, Oct 26, 2016.
  1. compet
    Apr 23, 2015
    3CX already have the billing code feature built in that only need to add an option on outbound rules that will only call if you have a gift billing code before the number. Going further you can also add a checklist so that it would only call if your billing code corresponds to a configurable list.
    we are in great need of this solution to make progress on one of our telecom projects
