Blackberry Apps
Discussion in 'Windows' started by bduke08021, Jul 2, 2010.
  1. bduke08021
    Jun 20, 2009
    34
    Is their a blackberry softphone app for this system?
  2. carolinainnovative
    May 4, 2009
    369
    5
    Not specifically for this software but any generic SIP client should work.
    Of course, true "unlocked" sip clients for blackberry are a rarity.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I have yet to find a usable SIP softphone for Blackberry. I finally switched to Android.
  4. carolinainnovative
    May 4, 2009
    369
    5
    Yeah - unfortunately, that has been my determination as well. Something about full-duplex audio being extremely difficult if not impossible in the blackberry API... and their relatively LOW cpu power.
  5. bduke08021
    Jun 20, 2009
    34
    That's what i thought, Thanks
  6. Aviator168
    Jul 28, 2010
  7. carolinainnovative
    May 4, 2009
    369
    5
    Have you actually gotten it to register AND make calls with 3cx? I had zero luck even getting it to run well...
  8. KerryG
    Jun 19, 2009
    960
    Any product that says their current version number is Beta 0.5xx tells me I probably should stay away from it for a while.
  9. Aviator168
    Jul 28, 2010
    swampcat got it working with a few of his servers include the 3cx.
    http://blackvoib.com/Support/index.php?topic=100.0
  10. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If anyone has got this working it would be intersting for you to post your cinfiguariton settings, it will help users to that are utilising a blackberry phone to get this working.
  11. jcasares
    Dec 5, 2009
    92
    No luck here. :(
