Blacklist by dial code
Discussion in '3CX Phone System - General' started by pai, Jun 23, 2016.
  1. pai
    pai
    Jun 23, 2016
    6
    Is there a way to blacklist the last call received by pressing a dial code?
    Ray
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    This feature is not available at this time. Perhaps you could post this is the Ideas section of the forum and if it gets enough votes maybe it will get implemented in a future release.
    http://www.3cx.com/forums/3cx-ideas-f57.html
  3. leejor
    10,779
    286
    At this point, the problem, is that the number blacklist applies to the entire system, not just one extension. So, although you may not want to receive any calls from the last number, others may feel differently. There would have to be an option that applied to each extension individually. Having this feature work with DID calls is one thing, but if a receptionist put the call through, then the call was "restricted", so that the call ended, or rang continuously, they may simply call back and complain to the receptionist, who may not know why the call failed.
  4. pai
    pai
    Jun 23, 2016
    6
    OK.
    Thank you
  5. engprod
    Apr 18, 2017
    There should be a way to do this by dial code. It should be a system-wide option that can be enabled or disabled. So, if you are a company that is concerned about your receptionist blacklisting wanted calls, you can disable the feature or only make the dial code known to approved people.
