Blacklisted Numbers / export type
georgi0
New User
can you edit this list for multiple entries?
what is the EXCEL file save as type to make the export file work in v.15.5.0 ?
You can only import entries into the list. The file format it accepts is .csv, meaning comma separated values.
Although there is no explicit instructions somewhere explaining what format the information should be inside, its quite simple to explain:
  • 1 entry per line
  • On each line, first the number, followed by a comma, then the description. Best avoid using spaces.
Example:
Reactions: apostolis_3CX
unfortunately i entered a big file and now i have more than 40 pages of entries entered wrongly. bext to the number is the description as well.
will the system see the first part and block the number?
could i somehow mass edit these entries ? where does 3CX keeps these records?
Mass edit no, is not possible, but by the time that the number you want to block is in the "Blacklisted Caller ID" column, you should be fine.
Getting Started - Admin
davide.luppi
Get 3CX - Absolutely Free!
3CX
