Blacklisting IP's like crazy
Discussion in '3CX Phone System - General' started by AH2, Apr 13, 2017.
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    After updating today, 3cx has blacklisted my own ip 3 times already, no idea why, it's connected on MAC with ext 102, and on android cell with ext 101.
    Is there a way to unlock an ip without admin panel ? via command ?
    Thanks,
    AH
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    The logs should indicate why it was blacklisted. Can't you remote desktop in to the 3cx server and login / white list yourself from there ??
    Or just remote in to some other computer on another Internet connection and login from there.
