BLF Buttons on GrandSteam Wave App?
Discussion in 'Android' started by neotheghost, Dec 12, 2017.
  1. neotheghost
    Dec 12, 2017
    6
    I think the GrandSteam Wave App is the best VOIP App out there.
    It's free and supports BLF. Those work great with Asterisk based PBXs, unfortunately i couldnt get 3CX PBX to show the presence status of other extensions.
    Anyone has some experience with Grandstream Wave and 3CX?
