BLF Drag and Drop
Discussion in 'Ideas' started by Nikoolaj, Oct 13, 2016.
  1. Nikoolaj
    Nov 7, 2014
    Being able to change the order of configured the BLFs through the BLF-tab on extensions.
    Also a feature to change the order (A-Z or 0-9) would be a huge benefit.
    jfletcher likes this.
