BLF for Queue Q Log IN/OUT
Discussion in 'Ideas' started by naveensenapathy, Jul 20, 2017.
BLF for Queue Q Log IN/OUT 5 5 14votes
5/5, 14 votes
  1. naveensenapathy
    Apr 24, 2013
    10
    5
    In future any way to add BLF option for Queue Log IN/OUT status(green/red) for supported ip phones?
    Currently we can set Agent Log IN/OUT button, but we can't see the status on the ip phone itself.
    Lucas Garcia likes this.
  2. Andrzej Pierscionek
    Jul 6, 2017
    14
    I've got exactly this quetsion from customer today.
  3. mortenjorge
    Apr 1, 2015
    58
    11
    I've solved this with XML scripts on Yealink phones - Works just fine - But yes, it would be nice to have this as a standard feature.
  4. bravad
    Feb 17, 2016
    17
    10
    Mortenjorge,
    Want to share your SCRIPT? Or send the path to follow to achieve the result ;-) thx
  5. mortenjorge
    Apr 1, 2015
    58
    11
    Hi Bravad.
    Theres different ways to show it.
    I'll do it with a white text pasted on the background.
    Our Script runs different others scripts.
    You need to upload your XML file to a webserver (could be 3CX).
    And use the <message> tag.
    I'll use:
    <Message Size="double" Align="left" Color="green" Icon="Message" Padding="2" > *** You're signed in ***</Message>
    for the message to appear.
    Go through the Yealink XML documentation, you'll find brilliant stuff in there :)
    bravad likes this.
  6. bravad
    Feb 17, 2016
    17
    10
    Thx !
  7. it4business2
    Nov 18, 2015
    7
    5
    Would be very nice!
