BLF Labels on Yealink
Discussion in '3CX Phone System - General' started by steszb, Feb 20, 2018.
  1. steszb
    Oct 4, 2017
    I recently had to change some names on a few extensions, and they have not pushed out to the BLF keys on Yealink T42G phones. I was hoping that simply restarting switches/firewall would force the update to all of the Yealink phones, but this was not the case. To update the softphones, I re-provisioned them from the management console, as there were only a handful.
    Viewing an extension's BLF keys in the 3cx management console reflects the correct keys and names. However, the DSSKeys in Yealink do not reflect the changes. Re-provisioning, rebooting and updating the firmware do not resolve this. It is only resolved by factory resetting it and also manually changing the labels in the DSSKeys, of couirse.
    Is there a more efficient way to push out these changes that does not entail making changes on each individual phone?
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    I have the same issues on a T48G.
    I ended up disabling updates and modifying the BLFs at the phone web page.
    Thankfully I only have one.
  3. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    861
    126
    What version of 3CX, how are the phones provisioned. standard or custom templates ?
  4. saqqara16
    Jan 13, 2016
    43
    5
    If you access the webfront of the one of phones, what settings do you have for Auto Provision - Power On , Repeatedly
    Tested on T42S phone on v15.5 SP3 work fine, if I restart the phone (instead of waiting for the above settings)
