BLF Light on Yealink
Discussion in '3CX Phone System - General' started by aly@accendo.dk, Nov 21, 2011.
  1. aly@accendo.dk
    Jun 15, 2011
    22
    We are currently using Yealing T38g and have set up BLF light on the phones. It works perfectly on local extension. Is it possible to set up, so when a mobile number i calling to an internal extension, a blf light will blink?
    Alex Lyman.
  2. purpleone
    Mar 18, 2009
    18
