BLF light to monitor group
Discussion in 'Ideas' started by Gav, Feb 26, 2018.
BLF light to monitor group 5 5 5votes
5/5, 5 votes
  1. Gav
    Gav
    Oct 3, 2017
    45
    I'd like the ability to bind a BLF light to monitor a ring group?
    ie - If any phone within a ring group is ringing, the BLF light on phone will flash.
    This would give all members of any group visibility of calls coming in to their department, regardless if call went to ring group or individual extension.
  2. timmbo
    Aug 25, 2017
    99
    47
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    Similar need - BLF for a Ring Group that is a Multicast Paging Group.
  4. jed
    jed New Member
    Feb 1, 2010
    153
    48
    And the posibility to add a BLF for any Call Queues, thank you...
  5. Jason Spruill-Jenkins
    May 8, 2017
