BLF on 48G not updating
Discussion in '3CX Phone System - General' started by jimbo59, Dec 18, 2017.
Tags:
  1. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    I'm changing the BLFs on a T48G Yealink with current firmware and they don't update. I have rebooted the phones and powered down and there is no update. Oy vey!
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi Jimbo59,
    Try re-provisioning the handsets and see if that works.
  3. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    This firmware has problems with 3CX. It no longer reboots the phone when necessary. Hotdesking doesn't reboot and BLFs don't force a reboot. It's not very usable. Thank god I only have one of these phones.
    I gave up on hotdesking.
    Now I reprovisioned after a factory reset and EXP40 doesn't see the BLFs I configured. Now I have to manually put them in through web interface. This phone wasn't well tested with this firmware. The old firmware worked fine.
    #3 jimbo59, Dec 18, 2017
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @jimbo59
    Please note that with the newer firmware phones do not reboot when re-provisioned specifically for hotdesking to work.
    For blfs to be added to the EXP40 when a phone is used for Hotdesking all blf spots on the phone must be filled before you can start adding blfs to the EXP unit. This is because different extensions with different blf configurations can use the same device and so blf keys are provisioned to the next available spot on the phone.
    When the device is not configured for Hotdesking then you can leave empty blf spaces and provision all your blf keys to the EXP unit.
    I have just tested a T48g and BLFs are added on the phone with a reprovision. I am running SP2 with firmware 35.82.0.20 and the default template.
    How is the phone provisioned? Local or remote?
  5. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    I did have some empty spots before the EXP unit. This phone is local.
