BLF on Cisco 508G
Discussion in '3CX Phone System - General' started by ycon, May 4, 2011.
  1. ycon
    Mar 15, 2011
    hi there,
    I have two brand new Cisco 508G (without sidecar).
    I want to configure BLF keys in order to get SD+BLF+CP.
    Trying manually (directly on the phone web site) or using the provisioning of 3CX, I get the same:
    the keys configured to call/pickup/led a specified expension can call but BLF don't seem to work: the led remain orange, even if the extension in free or is busy. even if the other extension is receiving a call, the led on my phone doesn't change.http://www.3cx.com/forums/posting.php?mode=post&f=1#
    here my function line:
    extension: disabled
    share call appearance: private/shared (doesn't change nothing)
    ext function: fnc=sd+blf+cp;sub=120@192.168.1.19:5060;nme=120
    any suggestion will be appreciated.
    thankx
  2. ycon
    Mar 15, 2011
    [SOLUTION]
    Sorry all,
    I've found the solution.
    BLF on Cisco work only on a licenced versione (not Free).
