BLF - PSTN
Discussion in '3CX Phone System - General' started by mattstarkie23, Apr 22, 2009.
  1. mattstarkie23
    Apr 21, 2009
    Hello
    Again any help would be much appreciated.
    We currently have a system connected to the outside world, the phones are grandstream 2000 and the PSTN gateway is a Grandstream 4104.
    I was wondering if there is any way to monitor the status of the outside lines?. We currently have 2 lines and so the grandstream pstn box has 2 ports set up (10000 & 100001). We currently make use of the busy lamp feature for monitoring other extensions, i was wondering if you could use this feature to monitor the outside lines instead of extensions?
    Thankyou to anyone that can help,
    Matt Starkie
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    try to program it to 10000,10001 as ext.
    I'll try it also and tell you
