BLF Setup
Discussion in 'Ideas' started by craigreilly, Mar 1, 2018.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    https://www.3cx.com/sip-phones/busy-lamp-field-dss-keys/
    Would be nice if this page had information about where the Physical BLF's start for different phone types. It took a while to decode the template and figure out the Grandstream 2140 starts at #11 in the 3cx console and the Grandstream 2160 starts at 23.
    Thanks for your time.
    Michael Groom likes this.
