BLF/shared parking pickup on android/ios
Discussion in '3CX Phone System - General' started by hogan71088, May 19, 2017.
  1. hogan71088
    Nov 30, 2015
    62
    Does anyone know if it's possible to pickup a shared parking blf on the android/ios app?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,557
    300
    You would have to add it to your iOS/Android phonebook. There have been reports that Android can not do this.
    Another way is create an extension (I use 771, 772, etc - 77 for SP - easy to remember.)
    Set the email to my own. Send me an invite. Provision my softphone. Set the extension to forward calls to SP? when not registered.
    Do this process for each SPx.
    When done, reprovision softphone for your own extension.
    Not the SP extensions are not registered.
    On iOS, Android - dial the new extension and voila.
    There are NO BLF's in the manner of a traditional SIP phone.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    try clicking on the top left of the client where the 3CX logo is and see if the android keyboard pops up. When it does try to pick up a shared parking by typing the shared parking in capital letters like SP1
