BLF showing question mark
Discussion in '3CX Phone System - General' started by cbodor, Aug 6, 2010.
  1. cbodor
    Aug 6, 2010
    Hello
    Just upgraded to version 9 from 8. Looks good! However my BLF soft keys on my aastra 57i CT now show a "?" instead of the phone icon, and do not light up when the extension is active. I add them all via the instructions on the support site and they where working before the update. Normally they should show a little phone icon not a ? and of cource light when up the extension is in use. Does anyone have any suggestions?
    Thanks in advance.
    -Colin
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    reboot the phone. Let us know how this progresses.
