BLF Snom 720 V15.5
Discussion in '3CX Phone System - General' started by Nicolas V., Nov 8, 2017.
  1. Nicolas V.
    Aug 31, 2017
    18
    After a server upgrade from V14 to V15.5 the BLF on the Snom have changed of behavior.
    In V14 when a extension wasn't busy but idle, the led on the BLF was off.
    Now in V15.5 the BLF are permanent green. (not cool for colorblind people)
    On Yealink it's very easy, i know how to do it in the XML templates, but can't find the parameter in the snom provisionning template. Is there someone who can help me with this ?
    Thanks you.
