BLF with intercom
Discussion in 'Ideas' started by daneke, Nov 5, 2017.
  1. daneke
    May 8, 2017
    46
    My customer came from NEC and prefers to press a button for intercom but still see if the extension is in use. Yes I can use a custom but that has no blf status.
    Now they press *9 and the button for the Htek phones but that doesn't work for Yealink
