- Joined
- Oct 18, 2012
- Messages
- 1
- Reaction score
- 0
System was running fine on V10.
Then moved to V11 (backup, uninstall V10, install V11, restore).
Everything went fine. System is running OK.
Problem: BLFs with assigned direct calls are now blinking ambar (but working fine).
Try to play with the provisioning template but no look.
Disabling provisioning will fix the blinking (but still is ambar).
Same situation with an SPA502G + 500S sidecar.
Any clues?
Thanks in advance
Any clues?
Thanks in advance
