blind transfer causes phone to freeze
Discussion in '3CX Phone System - General' started by weebnuts, Sep 26, 2007.
  1. weebnuts
    Sep 13, 2007
    37
    I have been trying to blind transfer between my two aastra 55i and 57i phones, and every time, the call transfers, but the phone that originally sent the transfer has to be restarted, it keep freezing. Is this an aastra problem or a 3cx?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I would say, that would be astra problem and not 3CX, Transfers here work fine, blind or attended...
    Cheers
    Try to look on the internet for foruns with a bit more info, or wait for some more answe :|
  3. weebnuts
    Sep 13, 2007
    37
    I disabled the support re-invite as well as tried to bind to media server, and still no luck.
  4. weebnuts
    Sep 13, 2007
    37
    Update:
    it also is causing the 3cx PhoneSystem service to shutdown.
  5. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Have you tried already to reinstall 3CX? If so, try to install 3CX on another computer, might be some software causing 3Cx to crash....
    Cheers
  6. evdbovenkamp
    May 31, 2007
    5
    Weebnuts,
    Do you already have found a solutions for the freezing of the Aastra phones when transferring a call?
    Erwin
  7. pacific
    Oct 24, 2008
    You need to upgrade your firmware on these Aastra phones. It should solve your problem. I had the exact same issue and upgrading the firmware solved it. 888voipstore has a "how to" on the upgrade. The actual sip upgrade file can be gotten from the Aastra- North American terminals link, on the Aastra web site. After the upgrade, reset to factory defaults and reconfigure. It should work.
    Jim Green
