Solved Blind Transfer changed each night
Discussion in '3CX Phone System - General' started by daneke, Aug 29, 2017.
  1. daneke
    May 8, 2017
    46
    I have a yealink 48G and some Htek 862 phones all up to date.
    Inside the webpage for each phone I can set transfers to be blind, but each morning they're back to being attended. How can I keep this setting permanent or is there another place to make them blind when pushing a BLF button?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    daneke likes this.
  3. daneke
    May 8, 2017
    46
    That was it...thanks
