Blind transfer fails
Discussion in '3CX Phone System - General' started by Paulh, Aug 3, 2010.
  1. Paulh
    Apr 16, 2008
    27
    Hi all,
    I just recently upgraded to version 9 (from 8 ). Backed up my settings under 8 and restored back to version 9 so all settings stayed the same.
    I have an issue now where all blind transfers (i.e. pickup call, transfer button, dial number, transfer) fails and disconnects caller. Makes no difference whether ogrinal caller is internal or external.
    Non blind transfer (i.e. party being transferred to picks up before transfer occurs) is working. Only blind transfer fails.
    it worked fine under v8. Phones are SPA941. Running on SBS2008 with the non IIS web server (can't remember what it's called off top of my head).
    Here is the log:
    16:35:50.343 [CM503003]: Call(39): Call to sip:103@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.187:5060
    16:35:50.270 [CM503008]: Call(38): Call is terminated
    16:35:50.221 [CM503008]: Call(39): Call is terminated
    16:35:48.251 [CM503025]: Call(39): Calling Ext:Ext.103@[Dev:sip:103@192.168.0.187:5060]
    16:35:48.203 [CM503004]: Call(39): Route 1: Ext:Ext.103@[Dev:sip:103@192.168.0.187:5060]
    16:35:48.202 [CM503010]: Making route(s) to "persons name"<sip:103@192.168.0.100>
    16:35:48.201 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:100@192.168.0.100:5060]
    16:35:48.199 [CM503001]: Call(39): Incoming call from Ext.100 to "persons name"<sip:103@192.168.0.100>
    16:35:45.588 Currently active calls - 1: [38]
    16:35:42.694 [CM503003]: Call(38): Call to sip:100@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.187:5060
    16:35:42.691 [CM503003]: Call(38): Call to sip:100@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.184:5060
    16:35:42.578 [CM503007]: Call(38): Device joined: sip:100@192.168.0.191:5060
    16:35:42.577 [CM503007]: Call(38): Device joined: sip:102@208.122.63.116:54185
    16:35:42.575 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:100@192.168.0.100:5060]
    16:35:42.575 [CM503002]: Call(38): Alerting sip:100@192.168.0.191:5060
    Anyone have any ideas?
    Thanks,
    Paul
  2. Paulh
    Apr 16, 2008
    27
    Bump. Does anyone have any ideas? Thanks!
  3. Paulh
    Apr 16, 2008
    27
    No one has any ideas? Please?
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    I suppose you have forked ID on ext 100. Connected device has IP 192.168.0.191, and 487 response comes from 192.168.0.184
  5. Paulh
    Apr 16, 2008
    27
    Archie,
    So yes, we have some of the same extensions on different handsets. However:
    a) the same issue occurs even one an extension that is on one physical phone
    b) we never had any problems with this until we upgraded to version 9 when it started happening
    We keep hanging up on callers because we're used to doing blind transfers, so it's important we get this fixed. Anything I should look at?
    Thanks!
  6. archie
    3CX Support
    Aug 18, 2006
    1,299
    Show us piece of log with failed blind transfer. The one you cited doesn't have blind transfer example.
  7. Paulh
    Apr 16, 2008
    27
    Archie,
    See below (internal call from ext 100 to 102 (Name1) and then transferred to ext 105 (Name2)). Let me know what you think. Thanks!
    11:44:44.787 [MS105000] C:297.1: No RTP packets were received:remoteAddr=192.168.0.187:16446,extAddr=0.0.0.0:0,localAddr=192.168.0.100:7038
    11:44:44.256 [CM503003]: Call(298): Call to sip:105@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.184:5060
    11:44:44.128 [CM503008]: Call(297): Call is terminated
    11:44:44.109 [CM503008]: Call(298): Call is terminated
    11:44:42.376 [CM503025]: Call(298): Calling Ext:Ext.105@[Dev:sip:105@192.168.0.184:5060]
    11:44:42.333 [CM503004]: Call(298): Route 1: Ext:Ext.105@[Dev:sip:105@192.168.0.184:5060]
    11:44:42.277 [CM503010]: Making route(s) to "Name2"<sip:105@192.168.0.100>
    11:44:42.276 [CM505001]: Ext.102: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:102@192.168.0.100:5060]
    11:44:42.274 [CM503001]: Call(298): Incoming call from Ext.102 to "Name2"<sip:105@192.168.0.100>
    11:44:34.909 [CM503003]: Call(297): Call to sip:102@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.184:5060
    11:44:34.897 [CM503003]: Call(297): Call to sip:102@192.168.0.100 has failed; Cause: 487 Request Terminated; from IP:192.168.0.193:5070
    11:44:34.820 [CM503007]: Call(297): Device joined: sip:102@192.168.0.191:5060
    11:44:34.819 [CM503007]: Call(297): Device joined: sip:100@192.168.0.187:5060
    11:44:34.816 [CM505001]: Ext.102: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:102@192.168.0.100:5060]
    11:44:34.816 [CM503002]: Call(297): Alerting sip:102@192.168.0.191:5060
    11:44:32.521 [CM503025]: Call(297): Calling Ext:Ext.102@[Dev:sip:102@192.168.0.191:5060]
    11:44:32.518 [CM503025]: Call(297): Calling Ext:Ext.102@[Dev:sip:paul@192.168.0.184:5060]
    11:44:32.515 [CM503025]: Call(297): Calling Ext:Ext.102@[Dev:sip:102@192.168.0.193:5070;line=56280]
    11:44:32.491 [CM503004]: Call(297): Route 1: Ext:Ext.102@[Dev:sip:102@192.168.0.193:5070;line=56280,Dev:sip:paul@192.168.0.184:5060,Dev:sip:102@192.168.0.191:5060]
    11:44:32.482 [CM503010]: Making route(s) to "Name1"<sip:102@192.168.0.100>
    11:44:32.481 [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:100@192.168.0.100:5060]
    11:44:32.479 [CM503001]: Call(297): Incoming call from Ext.100 to "Name1"<sip:102@192.168.0.100>
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    1) It is not blind transfer, it is attended transfer (at least - attempt tom make it)
    2) looks like 105 rejects incoming call. Check codecs. Wireshark capture of this call may give you additional ideas
  9. Paulh
    Apr 16, 2008
    27
    Archie,
    Sequence to transfer calls from SPA phone:
    Answer incoming call
    press xfer button
    dial number
    press xfer button again before pickup
    That's blind transfer, right? If other person picks up, then call isn't dropped. Again, this didn't happen with any previous versions of 3CX (7 or 8), only with 9. Phone settings were never changed. How would codecs affect blind transfer but not answered call transfers?
  10. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Just to help paul.
    I called from my cell to my spa942 (3cx v9 sp2) and answered.
    On my spa942 i then hit xfer, dialled ext 100, click dial then click xfer before 100 answered.
    All worked as expected. The cell was put on hold while i transferred. 100 rang and after my second transfer the spa no longer had the call
    So it is something in your setup. Best to run a wireshark now
  11. archie
    3CX Support
    Aug 18, 2006
    1,299
    Blind transfer is made within one call. You have two incoming calls: 297 and 298. It is not blind transfer. I have nothing to add. I don't know what you press on phone and whether something changed in config, but I see the log and I know what does it say exactly. Wireshark is next step to continue
  12. Paulh
    Apr 16, 2008
    27
    Ok, thanks. I'm not a network expert, so not sure what I would be looking for in wireshark...
    BTW, the fact that this is the free version wouldn't have any effect on transfers would it?
    Thanks.
  13. abc123
    Nov 9, 2009
    712
    I this situation it would.
    The free only has 2ccs I think (if you went to the demo) and as Archie said you are not doing a "by definition" blind transfer, you are doing an attended transfer but not waiting for the pickup.
    Your situation is like this:
    100 calls 102 (1 ccs)
    102 answers (now 2ccs)
    102 puts 100 on hold and calls 105(3 ccs - too many)
    Can you try a call from a cell phone to 102 and then the transfer. You should only be on 2ccs then.
  14. Paulh
    Apr 16, 2008
    27
    Actually, the free version has 4 simultaneous call capability. The transfer fails regardless of whether the call orginates internally or externally...
  15. abc123
    Nov 9, 2009
    712
    OK I went back and had a closer look at your logs and see the problem I think.
    You are using an SPA941 and it has at least two extensions registered on it (102 and 105) as I can see them being called on 192.168.0.184 but both on ports 5060. You cannot have multiple extensions on the same ip AND the same port. Change your 105 extension on the SPA 941 to register on port 5061 and it should work.
    The SPA941 has 4 lines (the same as my 942). You can register each line the same or individual extensions or a combination of both, but EACH extension (e.g 101, 102, 105) HAS to register on a different port (e.g. 5060, 5061, 5062). If you want to use the same extension on 2 lines on the phone (or 3) you register 1 extension and then tell the other two lines to use the first line (it is a drop down in the SPA941).
    Try that and see if it works now.
  16. Paulh
    Apr 16, 2008
    27
    Bingo! That was it! Now working perfectly, thanks ABC123! I don't know why we never had any problems before, but either way changing the ports fixed it. Thanks!
  17. Paulh
    Apr 16, 2008
    27
    Well, all was working fine up until today when it started not working again. Here is a screenshot of all the phones and ports. You can see no line on any phone shares a port with another line on that phone.
    The only change made was that I had incoming calls answered by IVR now I changed it so they're answered by ext 106. When 106 answers and attempts to transfer a call (answer->xfer->dial number->xfer) call gets disconnected.
    This is driving me nuts!
      File size:
      24.6 KB
      391
  18. coldtech
    Oct 5, 2010
    31
    I've had people saying they are having this problem with our SPA922's and thought they were just being idiots and hanging up on the people.
    They swear they are answering, hitting xfer, dial extension, announce call to extension answerer and hit xfer.
    Sometimes it works, sometimes not.
