In this case, I called an IP phone, and used its transfer button. (TRAN ext TRAN)
A (ext 575) calls B (ext 549)
B transfers to C(ext 540)
As you can see here this is all one call.
12-Jun-2013 09:22:46.166 Leg L:1400.4[VMail] is terminated: Cause: BYE from PBX
12-Jun-2013 09:22:46.166 [CM503008]: Call(C:1400): Call is terminated
12-Jun-2013 09:22:46.165 Leg L:1400.1[Extn] is terminated: Cause: BYE from 10.10.20.4:5060
12-Jun-2013 09:22:44.715 Leg L:1400.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.10.20.109:5062
12-Jun-2013 09:22:44.714 [CM503003]: Call(C:1400): Call to <sip:
[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.10.20.109:5062
12-Jun-2013 09:22:44.689 Leg L:1400.2[Extn] is terminated: Cause: BYE from 192.168.1.30:5062
12-Jun-2013 09:22:44.673 NAT/ALG check:L:1400.1[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
12-Jun-2013 09:22:44.535 [CM503007]: Call(C:1400): VMail:999 has joined, contact <sip:
[email protected]:40600>
12-Jun-2013 09:22:44.532 L:1400.4[VMail] has joined to L:1400.1[Extn]
12-Jun-2013 09:22:44.532 NAT/ALG check:L:1400.4[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
12-Jun-2013 09:22:44.418 [CM503025]: Call(C:1400): Calling T:VMail:999@[Dev:sip:
[email protected]:40600;rinstance=6c6cd3e7fe6b8f19] for L:1400.1[Extn]
12-Jun-2013 09:22:44.362 [CM503005]: Call(C:1400): Forwarding: T:VMail:999@[Dev:sip:
12-Jun-2013 09:22:44.362 L:1400.1[Extn] forwards call from Extn:540 to VMail:999 based on rule Fwd[Available/NoAnsw]
12-Jun-2013 09:22:44.362 L:1400.1[Extn] failed to reach Extn:540, reason No Answer
12-Jun-2013 09:22:29.328 [CM503025]: Call(C:1400): Calling T:Extn:540@[Dev:sip:
[email protected]:5062] for L:1400.1[Extn]
12-Jun-2013 09:22:29.273 [CM503027]: Call(C:1400): From: Extn:575 (<sip:
[email protected]:5060>) to T:Extn:540@[Dev:sip:
12-Jun-2013 09:22:29.273 [CM503004]: Call(C:1400): Route 1: from L:1400.1[Extn] to T:Extn:540@[Dev:sip:
12-Jun-2013 09:22:26.052 NAT/ALG check:L:1400.1[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
12-Jun-2013 09:22:25.925 NAT/ALG check:L:1400.2[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
12-Jun-2013 09:22:23.008 [CM503007]: Call(C:1400): Extn:549 has joined, contact <sip:
[email protected]:5062>
12-Jun-2013 09:22:23.007 [CM503007]: Call(C:1400): Extn:575 has joined, contact <sip:
12-Jun-2013 09:22:23.005 L:1400.2[Extn] has joined to L:1400.1[Extn]
12-Jun-2013 09:22:23.005 NAT/ALG check:L:1400.2[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
12-Jun-2013 09:22:21.940 [CM503025]: Call(C:1400): Calling T:Extn:549@[Dev:sip:
12-Jun-2013 09:22:21.934 [CM503027]: Call(C:1400): From: Extn:575 (<sip:
[email protected]:5060>) to T:Extn:549@[Dev:sip:
12-Jun-2013 09:22:21.934 [CM503004]: Call(C:1400): Route 1: from L:1400.1[Extn] to T:Extn:549@[Dev:sip:
12-Jun-2013 09:22:21.932 [CM503001]: Call(C:1400): Incoming call from Extn:575 to <sip:
12-Jun-2013 09:22:21.931 NAT/ALG check:L:1400.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
