Blind Transfer Ringtone
Discussion in '3CX Phone System - General' started by comresource, Nov 21, 2013.
  1. comresource
    comresource Member
    May 22, 2009
    303
    We have a client who would like to change the Blind Transfer Ringtone. Can this be found in the provisioning template? If So, where?
    Thank you,
    Dan
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    The transfer ring tone is the same as the on hold music under the general settings...
  3. comresource
    comresource Member
    May 22, 2009
    303
    OK looks like I have a clarification from the client. It's a very simple set up. There are roughly 7 users in one ring group. When a call comes in, they all ring at the same time with the Ring1.wav on Yealink T38gs. I now have it set (per client's request) so if no one in the ring group answers, it goes back to him only, BUT, he wants that secondary ring tone to be different (different than Ring1.wav). Is there a setting for this?
    Thank you
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Sounds like you want distinctive ring based on the workgroup or ring group. You need to dive into the phone's template to do this. It is possible to select another ring.
