Block a prefix from being dial from extension 104
Discussion in '3CX Phone System - General' started by wdcsinc, May 25, 2008.
  1. wdcsinc
    Oct 5, 2007
    Dear forum group, I would like to be able to setup a rule for ext. 104 that will block any calls dialed that start with prefix 1809 but at same time, I want ext 104 to make any other calls, in other words I want ext 104 not to be able to make calls to numbers starting with 1809 prefix, please advice on how to setup a rule that will allow me to block calls to numbers starting with 1809 but also allow me to make anyother calls to any dialed number, thanks. :p
  2. coelhopsi
    May 7, 2008
    84
    You can set up an outbound rule specifying the following parameters:
    Calls to Numbers starting with (Prefix): 1809
    Calls from extension(s): 104
    Route 1 / Route 2 / Route 3: <empty>
    Put this outbound rule in the first place on the outbound rules list (highest priority).
  3. wdcsinc
    Oct 5, 2007
    thanks for the advice it works great, keep up the good work thanks one more time!
