Block all Inbound calls to certain extensions
Discussion in '3CX Phone System - General' started by Jessep, Oct 9, 2014.
  1. Jessep
    Oct 9, 2014
    25
    I work in an environment where we would like certain extensions to be able to only make and receive internal calls. Outbound restriction is no problem but I am not finding anyway to disable/block all incoming external calls to certain extensions. Is this possible?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Select the extension under extensions node ---> options ----> restrictions ---> check disable external calls box.
  3. Jessep
    Oct 9, 2014
    25
    Unfortunately that only blocks outbound calls. I need to block calls coming into the building to these extensions.
  4. jpillow
    Jun 20, 2011
    1,342
    You just remove those extensions from ring groups.... If the desired extensions are not in the ring groups external inbound calls will not go to those extensions.....
  5. Jessep
    Oct 9, 2014
    25
    Can you elaborate, I don't understand. The extensions aren't currently in any Ring Groups or do you mean Extension Groups? Thanks
    jesse
  6. leejor
    10,754
    286
    I'm assuming that you mean to block outside calls, originating through a digital receptionist.
  7. Jessep
    Oct 9, 2014
    25
    Exactly what we are trying to do.
  8. Jessep
    Oct 9, 2014
    25
  9. leejor
    10,754
    286
    There are a number of call forward options associated with each extension along with the ability to differentiate between inside and outside calls...however ,they all pretty much rely on the user being unavailable, unregistered, or busy. If you want inside extensions to still be able to reach the extension in question, then you may be out of luck.
    Perhaps ring tone based on caller ID, where outside calls would simply not ring on the set?
  10. Jessep
    Oct 9, 2014
    25
    Interesting thought on the ring tone, not ideal but better than nothing I think. That would be done in the provisioning config file for those extensions?
  11. leejor
    10,754
    286
    I think that a lot depends on the type of set you are using and if it supports this feature.
    Here is some info, some of it is quite old unfortunately, and doesn't go into a great detail.
    http://www.3cx.com/blog/voip-howto/caller-id-processing-distinctive-ringing-alert-info/
    http://www.3cx.com/forums/distinctive-ringtones-yealink-t46g-39474.html
    http://www.3cx.com/forums/v11-distinctive-ringing-where-to-configure-29268.html
    http://www.3cx.com/forums/distinctive-ring-with-3cx-v11-30388.html
  12. Ben C
    Oct 14, 2014
    71
    I have a similar situation where outside callers reaching a specific 'Digital Receptionist' (i.e. 708) , should not be able to reach extensions 100-399, but they should be able to reach extensions 400-499.
    I created an outbound rule to prevent calls from 708 to numbers starting with 1, 2,3 (3 digit length). But it seems the outbound rules apply to extensions but not to 'Digital Receptionist'.
    Any workaround?
    Thank you
    Ben
  13. leejor
    10,754
    286
    It sounds as if a Feature Request to add extension restriction rules for DRs, and/or outside callers, is in order...
    http://www.3cx.com/ideas/index.php
