Block call by CID
Discussion in '3CX Phone System - General' started by wfranklin, Jan 6, 2016.
  1. wfranklin
    Jan 6, 2016
    Heys guys,
    I'm a newbie by 3CX PBX Systems but I'm just helping a customer here.
    Let's go.
    Is it possible block a call by CID? I mean by the source number? Let me explain more, I'm giving a 0800 number (I'm the ISP) to this customer but he does't want get calls from mobile numbers, so I wanna block this call on 3CX system.
    How can I do this?
    Thanks! ;)
  2. wfranklin
    Jan 6, 2016
    Adding.
    I know that can be something under ADD DID/DDI NUMBER.
    Thx
  3. AlexDBarrett
    Jan 25, 2011
    71
    9
    Do you mean inbound calls?
    If so add 07* to the Number Blacklist in Settings (V14)
  4. wfranklin
    Jan 6, 2016
    Hey Alex,
    I'm sorry I forgor to say that it's a Inbound call..
    Yes, but if I put it there I'll block all calls right? I'd like to block just to specific DID.
    For example.
    DID 0800 569 5641 - i'ts just a Toll Free number you know...
    Souce to DID is a Mobile Number: +55 11 9 98745698
    I need to block just the calls with +55119* to 0800 DID
    Got it?
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    Use the Extension # -> Forwarding Rules -> Exceptions if the DID is associated with just a single extension.
    But I am not sure about this if the DID goes to a ring group/queue/etc.
  6. wfranklin
    Jan 6, 2016
    craigreilly
    This sounds good to me but I was wondering if that calls go to Group? It will not work beucause there we don't have this option, is int'?
    How about Inbound Rules > Inbound Rule Type > C ID number? What do u think? How can I accomplish it?
    Thx a lot.
  7. leejor
    11,105
    329
    Unless things have changed recently, you can "deal" with CID at the extension level, or a blanket "rule' that affects everyone. If you choose to block a number for the PBX, I don't believe that you can block by prefix, left to right. If the call is routed to a ring group, or non-extension "initial" destination, you could route the call through a "dummy" extension and parse the CID at that point, although, again, I'm not certain that it is designed to deal only with a numbers prefix ( make use of wildcards).
  8. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    You could probably get this done by adjusting the order of the Inbound Rules.
    Maybe you could do something around the lines of e.g.:
    - DID A -> Ext A
    - DID B -> Ext B
    - DID X -> Ext X
    - CID +55119* -> block calls
    - DID 0800 -> Queue
    This way on every inbound call it would first go through all the other rules and if it reaches the end, right before hitting the 0800 DID rule have a CID rule that would block calls from mobiles. Haven't tried it but I think it should work.
