Block calls to other extensions
Discussion in 'Ideas' started by kinetix3, Mar 29, 2018.
Block calls to other extensions 5 5 1votes
5/5, 1 vote
  1. kinetix3
    May 13, 2014
    I would like the option per extension to be able to block calls to other extensions, including system extensions, ring group exts, etc.
    Our issue is that a customer has a courtesy phone for customers to call out, but they can also access the paging system and other extensions.
