Block extension calling
Discussion in 'Ideas' started by GDavid, Jan 25, 2016.
  1. GDavid
    Mar 16, 2015
    6
    Block Dialing Extensions
    Need the ability to restrict dialing certain extension from a specific group.
    For example: Fire Station A, can't seem to stop themselves from dialing the paging ext for Fire Station B.
    Simply changing the extension or disabling it are not permanent solutions.
  2. digital46
    Sep 20, 2013
    I have clients who would like to block specified extensions from extension dialing and have those specified extensions only be able to dial to external numbers.
  3. christiaanprionet
    Feb 11, 2016
    On all extensions configure exeptions under forwarding rule and make rules specific for the extensions numbers.
    Hope you understand
  4. PaulD
    Jul 4, 2010
    78
    8
    Managing via the forwarding exceptions will work but you'll find that there isn't a way to 'Allow' specific extensions - so it gets very messy - doable but a PITA (that's Pain In The Arm ;) ).
    You may wish to read/consider 'Upvoting' this thread which would definitely help .....
    forwarding-rules-exceptions-exception-43659.html
