Block incoming call by caller ID
Discussion in '3CX Phone System - General' started by tdy, Jun 28, 2010.
  1. tdy
    tdy
    Jun 28, 2010
    10
    Hello all,
    Iam using IP Polcom phones, Grandstream GXW 4008 gateway for all analog phones, and VOIP provider ViaTalk.
    Really new to this whole telephony stuff,but everything is working. :)
    What i was wondering is how to block certain incoming calls from "outside" world, by the caller ID. Is there a global setting for this? so it would apply to all extensions?
    Troy
  2. dab
    dab
    Nov 1, 2009
    67
    IMHO there is no global setting, you can just specify it per extension, with max of 15/extension.
    I've you to block only a few CID, you possible can direct edit it in the database for each extension.
    But this will not be supported by 3CX, but possible will be a reasonable fix for you.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    V9 actually does have this feature implemented, altough it is in beta stage, you should upgrade to it if you really need it.
  4. tdy
    tdy
    Jun 28, 2010
    10
    Ok, i might do that. Do you have a link to download the V9?
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
  6. wzaatar
    Aug 1, 2007
    90
    On V8, You can also consider using the 'trick' of a forward to an always-unregistered extension and use incoming rules filtering by CallerID.
    Let me know if you want help setting this up.
  7. tdy
    tdy
    Jun 28, 2010
    10
    Hmmm... thats interesting, does this work with the free 3CX?
    Troy
  8. mfm
    mfm Active Member
    Mar 4, 2010
    641
    That workaround would work with the free edition as those specific parts of the extensions are not disabled.
  9. wzaatar
    Aug 1, 2007
    90
    Yes,
    Works like a charm. ;-)
    W.
