Block WAN is on Mssg when trying trying to configure direct SIP or STUN
Discussion in '3CX Phone System - General' started by jwardlaw93, Mar 9, 2018.
  1. jwardlaw93
    Mar 9, 2018
    14
    I think at some point I did check a box that said something about blocking WAN connections, assuming I would not need to set up any remote phones.
    I am attempting to set a remote phone as a test for a customer and I keep getting the " Block WAN is ON" in the activity log.
    Does anyone know how to turn this back off?
    Thank you for the help!
    Joseph
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    Under the extension settings
    Options
    "Disallow use of extension outside the LAN"
    Michael Groom likes this.
  3. Michael Groom
    Dec 11, 2017
    63
    This
  4. craigreilly
    Feb 1, 2012
    3,569
    302
    maybe its this?
