Solved Block WAN requests is ON
Discussion in '3CX Phone System - General' started by Network Emad, Nov 26, 2017.
  1. Network Emad
    Oct 27, 2017
    33
    hello
    i got this alert on dashboard:
    SIP Server/Call Manager ID: 12291
    SIP request (REGISTER) from 20.1.1.1 was rejected. Reason: Block WAN requests is ON. Message: REGISTER sip:20.1.1.1 SIP/2.0 Via: SIP/2.0/UDP 20.1.1.1
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Somebody from this address: 20.1.1.1 was trying to register on PBX. Most probably an attack. Normal to have such messages from time to time. Be sure all passwords you use, are strong enough.
    Network Emad likes this.
  3. Network Emad
    Oct 27, 2017
    33
    ok
    but i installed 3CX on 20.1.1.1 and i got this message from the same server !! do you mean that
  4. sip.bg
    Nov 7, 2016
    704
    219
    Normally you should install the PBX on local address like 10.0.0.0/8, 172.16.0.0/12 or 192.168.0.0/16, as defined by RFC 1918.
    The address 20.1.1.1 is a public IP address and if you use it as private one, the PBX would not function properly. The case above means the address will be blocked for 1800 sec (default security setting), as the PBX received registration attempt from itself. By default extensions are not allowed to register from public networks. You may have other configuration issues too for causing the above event.
    Please review your settings and if necessary reinstall the PBX (you can't change local address of the PBX without reinstalling).
    #4 sip.bg, Nov 26, 2017
  5. Network Emad
    Oct 27, 2017
    33
    thank you
    i used 10.1.1.20 as default gateway instead of 20.1.1.20 and the message stop appearing.
