blocked from voice mail
Discussion in '3CX Phone System - General' started by hfournier, Jul 6, 2012.
  1. hfournier
    Feb 24, 2012
    38
    I have a user reporting that he is blocked from his voice mail after too many unsuccessful attempts (using wrong PIN). He says he remembers his correct PIN now.
    Is there a way to reset his voice mail to allow him access? Or does it reset automatically after a period of time? How long?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    To be honest, this is the first time I have run across this scenario. You might go into his extension and change the PIN to something else and apply. See if you can then access and if so, change it back to what it was and then you can try. If you can get the greeting, then there should be no reason that he can't.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Just go to the 3cx management console and you can change the PIN by double clicking on the extension, manually change the PIN click apply and your good to go.
