Blocked User Agent List, How To View This ?
Discussion in '3CX Phone System - General' started by Fatboy40, Mar 5, 2013.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Is there a way in 3CX v11 to view the contents of the 'blocked user agent list' ?, and if there is can you add your own entries to it ?.
    Thanks.
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Open Management Console. Go to Settings->Advanced and open Custom Parameters tab. Search for SEC_IGNORE_USER_AGENT
    From there you can see and edit your own list of blocked UA.
  3. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
  4. may.phyu
    Aug 21, 2015
    This blocked is related with calling from 3cx extension to outside PSTN .
