Blocking all numbers and Whitelisting good numbers
Discussion in '3CX Phone System - General' started by MichaelD, Aug 2, 2017.
  1. MichaelD
    Mar 27, 2010
    36
    Hello to all,
    Is there some way to set up 3cx so that it automatically blocks all numbers -- except those in a whitelist?
    I know this sounds extreme, but we spend waaaay too much time answering bogus calls!
  2. MichaelD
    Mar 27, 2010
    36
    Just bumping this up. Anyone have any ideas on this?
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Make an inbound CID rule with a mask of * with a destination of END CALL, then make an inbound CID rule for each number that is allowed and put it ahead of the * rule.
    If you need this to be database driven, voiptools has a caller-id router add-on that can read from a sql database. You can have it route the matched numbers to one destination and anything unmatched to an end call route.
