Blocking caller ID
Discussion in 'Windows' started by oliverm, May 12, 2010.
  1. oliverm
    Mar 10, 2009
    79
    Whats the easiest way to block our outgoing caller ID from showing with 3CX ?
    Olly
  2. pjr
    pjr New Member
    Oct 5, 2009
    154
    I think this is dependant on how you route your calls out?
    in the UK, if you are using BT ISDN, you can prefix your outbound call with 141 to withold CLI. I dont know of any SIP trunk providers that support this type of feature though - some allow you to withhold CLI by specifying certain values in certain fields in the invites, but I dont think its possible to amend these on a call by call basis from the softphone.
    Paul
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You have 2 choices really,
    1. Tell you provider, make my called ID anonymous.
    2. If there is a specific code to make your call ID anonymouse #31# it is over here, then you can add it as a prepend code for all numbers in your outbound rules.
