Blocking calls from anonymous callers
Discussion in '3CX Phone System - General' started by neville, Dec 22, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    202
    33
    The marketing calls are driving me crazy. Is there a way to drop/block calls from callers with anonymous, blocked, etc. caller id?
    Any other suggestions. As most of these callers switch number with each call, it is hard to block by number.
    Chuck
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    906
    137
  3. leejor
    10,367
    228
    I find that, at least in North America, telemarketers are on to that, they know that most people will not answer. I rarely see a blocked number. These days they can spoof any number they want. In many cases they will send a toll free number, or even a number with the same areacode and prefix as you, in the hopes you think is is someone local, and answer.
    #3 leejor, Dec 23, 2017
    viraltechnology and accentlogic like this.
  4. viraltechnology
    Mar 22, 2015
    39
    5
    I agree, I receive a ton of calls that spread to come from a local area code. I then just block that call by adding them to the block list.
  5. 3CXDude
    Oct 1, 2015
    94
    24
    We don't use blacklists anymore.
    I setup a queue with dummy extension in it and max wait time of 5 hours (18000 sec) and use CID rules to route their CLIs to it. You can usually see a pattern in the CLIs and can then use wildcards where suitable.
    It gives a little pleasure to see them stuck in a Q for 5 minutes before hanging up. You can even report on it :)
    Within 3 months or so, we went from daily calls to near 0 and I consider that a WIN :D
    P.S. be sure to use some sort of depressing music for that Q too
    apostolis_3CX and sip.bg like this.
