Blocking calls to a given dialing code
Discussion in '3CX Phone System - General' started by oliverm, Oct 10, 2011.
  1. oliverm
    Mar 10, 2009
    79
    Hi chaps
    I want to block calls to given dialling code. From what I can gather the only real way to do this is the following. Can someone check that this is correct?
    1) Create a fake VOIP provider entry for a provider we dont use
    2) Create an outbound rule for calls to 9xxxx and set the "make outbound calls on" to use the fake provider
    3) Sit back and check for screaming users
    Is that about right?
    Olly
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    no need to create a SIP Provider look at the below image
    you will see that i have not defiend any call routes.
    Simply apply and move the block rule to the top of the list.
      File size:
      154.6 KB
      551
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please specify call scenario where it should be blocked?
