Blocks of DID's
Discussion in 'Ideas' started by business54, Nov 18, 2016.
Blocks of DID's 5 5 9votes
5/5, 9 votes
  1. business54
    Apr 20, 2016
    56
    How is there not a way of adding a block of DID's to SIP trunks? Do I really have to add each DID one at a time?
  2. AndyBarr
    Apr 8, 2015
    33
    This is really infuriating - I am now entering 200 DID manually and having to scroll to the top and click on ADD DID each time!!
  3. red45
    Nov 4, 2014
    57
    15
    Agreed, kind of crazy, simple oversight.
  4. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    use the "import inbound rules" - this will create dids in the trunks.
  5. red45
    Nov 4, 2014
    57
    15
    Yes, we saw that. But then don't you need to then go back and delete all the rules if you don't want to assign them yet? Still seems a bit clunky.
  6. wizdude
    Feb 27, 2017
    importing the DID's from a file is hardly a solution. i still need to generate a list of all of them to start with.
    all of the PBX's I currently work with have numbers assigned in 100 DID blocks. I would have thought that an obvious feature would be to permit entry of DID in a range.
    ie: add DID as: 0395551200-0395551299
    or even to permit an "X" as a wildcard would be fine,
    ie: add DID as: 03955512XX
    i've read through all the docs I can find - if this feature exists then i'd love to know about it. while i've been using other IPTEL phone systems and PBX's for many years, i'm playing with 3CX for the first time.
    after i've had more of a play, i might put together a feature request list and submit it.
    if anyone else has any good ideas for mass addition of number blocks please let me know :)
    cheers, wizdude.
  7. mcsantoso
    May 9, 2016
    9
    I believe previous versions you could add blocks of DIDs like that and V15 that feature is taken out apparently. This feature needs to be added back in.
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,097
    203
    Import works great and allows much greater flexibility as it can setup the destinations as well.
    Just export your current DID list and see.
    (Excel: Cell A2 formula '=A1+1' works great for sequential DID's)
