BLREC file format - log analyzing
Discussion in '3CX Phone System - General' started by sabe, Feb 5, 2016.
  1. sabe
    Feb 5, 2016
    Is there a description of the BLREC file format? Is it possible to feed it to a log analyzer program like SPLUNK?
    I know I can extract the contents with the logviewer, but i'd prefer to do it live - so the log events would automatically go to an external program.
    I would be happy to have the log events going to a text file instead of the BLREC files. Is there a way to do it?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    As far as I am aware it is a custom file type and there is no API that would allow to read it any other way except with the Log Viewer.
